NOS 69-70 standard chrome mirrors
Can anyone tell what a set of NOS chrome drivers & passenger mirrors are worth? These are for the standard not XR7. These are manual ajusting no cable. Can’t add photos file to large.
IMG_0257.jpg.zip (2.78 MB)
Ball park figure would be around $250 to $300 for the pair.
I have never seen a “standard” or non-racing mirror for the Passenger side before. Is it original? Can you share the part # on the base of the mirror? Thanks!
Passenger side does not have a part number, the drivers side does have one. They are a match pair. I will get them later. If I could srink the photos I would have photos. The passenger side has studs from the factory, drtivers side does not.
Drivers side part # C9WB-17683-A
Passenger side fomco stamp casting # 17743 AA
So the passenger side must be very rare.
I saved your picture to my flicker account and posted it for you. Did you realize both links you posted are the same picture?
Here is what the DS is worth used, they never made A PS in chrome, what is the casting # on the base?
http://www2.cougarpartscatalog.com/store/p/13512-Side-View-Mirror-Driver-Side-Chrome-Manual-Standard-Grade-A-Used-1969-1970-Mercury-Cougar.html?attribs=87
Don see this post from above.
Postby cougarrand » Today, 03:46
There should be some more to that 17743 AA #…
ok how about 17743AA 152823 I didnt think the last numbers were needed.
Usually with FORD part number will start with something like the other mirror has. C9WB for example. That number,17743 AA looks to be a good R/H mirror number, just short the prefix. I’m sure it is not there or you would have posted it.
I noticed that on the other side of the brace where the stud comes out there is a “D” on the passenger side mirror. Which means it is from the 70-79 year cars. It also has a different looking base, more hollowed out than the drivers side. Also the inside of the base on the passenger side is flat and the drivers side has more of a curve. It still might work for the passenger side if someone does not look to close. Thanks for all the help on this.
If you don’t need used I have NOS ones remote and non remote in stock. a couple of each left.
