One Light on Rear Taillight Dim
My brake light on the right side of my rear taillight is dim. The other two are fine. Left side is fine. Changed light with right side, but didn’t fix it. Would love some help on this one. Could it be the reflective surface of that one socket needs re-done? I haven’t taken the light assembly apart yet.
Most likely a bad or poor ground on that socket.
Probably a bad socket - it might be either power or ground. Swap sockets to prove that is what it is.
Thanks! But I’m a novice. Old but a novice. How do I verify that? I could use all the help you can give me. If it was anything other the the middle (brake light) I wouldn’t even bother.
Swap one socket that works properly into the position that doesn’t.
Thaks Royce! I swapped the socket for the one next to it, and all the brake lights lit up great! All 6 lights working properly now!
