So picked up a set of 67/68-style smog tubes on eBay but the bracket came off the driver side tube. Any ideas on the best way to repair this? Would I ask a shop to spot weld it back on? I don’t want it to look like a mess.
You could try drilling out holes where the dimples on the bracket are and filling them with weld then grinding it flush. It’ll look factory.
Yep this is a good suggestion and what I would do. just make sure you dial the welder down for the thinner material.
Use JB Weld - it will last a lifetime.
