Need to place wiring harness for 69 Mustang tilt away steering system.
What is the BEST way to access inside the drivere kick panel area to thread/place this harness to both the tilt switch and the courtesy lamp switch.
Limited space exists.
I just did this on a '69 XR-7. I had the dash out and the kick panel out. It is doable - just. There is no easy answer I am afraid.
So you removed only the the dash pad and gauge panel?
The dash panel, gauge panel, and kick panel. I started to remove the emergency brake pedal too but could see no gain in access so I stopped. It is a bitch of a job.
Thanks.
Now what do the two wires coming off the tilt cable canister connect to?
Thanks
