I am looking for a picture of the styled steel wheels that came on my 69 XR7.
I have been told that there were different ‘Styled Steel Wheels’ and I would like to see the correct ones.
Here’s what I know:
They were a $95.90 option and the build sheet info under “wheels” is:
Color L
Style S
Type A
Code P
[quote=“TheRktmn, post:1, topic:30251”]
Color L
Style S
Type A
Code P[/quote]
Where did you find this information? Asking because I have never heard, or seen this. Thanks
The price came from the Window sticker section of my Deluxe Marti Report.
The ‘Wheels’ info came from my build sheet found stuck in the springs of the back seat.
Re: different ‘Styled Steel Wheels’… Possibly they are referring to the '69 Eliminator wheels as one version of Styled Steel Wheel?
What exactly does your Marti Report show?
My '69 Eliminator build sheets show the following;
Color: L
Style: S
Type: A
Code: A
I THINK the typical Styled Steel Wheel option has Code: S, but I don’t have enough 1969 non-Eliminator build sheets to confirm that it is the same for '69 & '70.
Also check your build sheet field D-9 Wheel Covers and see if there is anything in that field.
And if you have your factory invoice, check and see what it shows as well.
My Marti Report and Window Sticker both say “Styled Steel Wheels”. No more description. Window Sticker shows an extra charge for $95.90 for the styled steel wheels.
My Build sheet is empty at D9 (Wheel Covers) and I have the same E7-11 you posted but but my E12 is a P, not an A.
I was guessing that the S in E10 was for Styled steel wheels.
