What would cause the power steering pump to squeal when the steering wheel is turned all the way in either direction? The reservoir appears to have enough fluid in it. Just when the wheel is turned to the full left or right, it wants to squeal, not excessively, but it squeals.
Belt is bad or not tight enough.
That fixed it. Sometimes it is always the simplest of things. Tightened the belt and no more squealing. Thank you cougarrand.
