It originally had AC but I’m not planning on putting that back. The only other accessories are the alternator and water pump.
The power steering pump is by itself in a fairly open area. There’s plenty of clearance where it is. I could put in something twice the physical size of the pump and it wouldn’t hit anything.
I just think it’s over boosted, especially when you’re driving over 70 mph. It gets just much more sensitive then I like.
It’s a 1968 with the original 302 engine block topped with GT-40 heads and an Edelbrock performer 289 intake.
Sure, the Borgeson unit will work, but it’s one Grand and involves cutting the original tilt away steering column back a few inches at the bottom & some think that’s extreme.
If you’re going to repair the power steering system, it’s a great time for modifications & a different pulley isn’t that expensive.
In terms of actually bolting it up, you can see for miles and miles. Any pulley size will physically install.
The range of adjustment the pump can be mounted on is very generous indeed.
It’s not uncommon to install under driven or over driven pulleys on belt driven accessories for various reasons on V8 engines…if you can find who makes the part!!
The '67 Shelby GT350 Mustang pulley will slow down the pump and give you better steering feel. Try SEMO https://semomustang.com ask to see a 7AC Power steering pulley.
