After finally getting the burned-up main engine harness spliced, I have been excited to work on my old tin cat, and getting lots done. While I have the AC box out, and entire dash disassembled, I decided to install the kick panel 6.5" speakers.
This is me, taking an accidental selfie while trying to photograph the bundle of wires I was color-matching:
I did a pretty clean job cutting the 5" holes in my kick panels. A hole saw on a typical drill will try to bind and kicks like a mule, so I can’t recommend this for the average person. I managed to hold it steady, and got nice clean cuts!
After cutting the holes, I filed the edges smooth, and painted them so that they wouldn’t rust later. It should be noted that my 6.5" speakers specified 5 5/8" holes. However, I took some bad advice on the internet and used a 5" hole saw for the job. Remarkably, the speakers still fit PERFECTLY despite the ‘too small’ openings.
I used stainless steel screws with nuts, and after drilling holes for them, I threaded them through. The screws had good bite in the sheet steel. With speakers on the inside of the kickpanel, I ran the screws in. I do not have a set of the original (optional) speaker buckets, and I was afraid they’d be too small anyway. So I opted for a couple of “Boom Mat” inexpensive foam enclosures to seal them. I used the trim ring from my speakers on the back side of the kick panel, and put nuts on the screws to secure everything. As you can see, the pigtail for the speaker itself is just laid under the foam up against the sheet metal. I’ve got some rubber plugs on order, and next I’ll drill a smallish hole, poke the wires through a plug, and use it as a grommet to keep them from fraying on the sheet metal. It should be airtight, but I also plan to use a shot of “Flex Seal” across the bucket and that plug. It will further strengthen the foam bucket, help deaden it acoustically, keep the nuts from ever backing off their screws, and ensure that everything is leak-proof.
And last but not least, here’s the original 1967 AM-jammer from my car. It looks stock (and is!) but it has all new internals from Aurora Design, allowing AM, FM, Bluetooth, Handsfree, and MP3!
I’ll try to get some pics of the USB port I put in my dash tray to replace the original cigarette lighter, next.
