67 Cougar tail light housing needs to be refinished. Came across a couple of YouTube videos where tail light housings were refinished using craft store glitter and clear coat spray, the results looked amazing (but not sure if it would last). Has anyone tried this technique? If not what have you found to be the best type of paint to help tail lights to be seen?
Best thing I’ve found after sanding the surface to assure it’s smooth and applying some silver paint on the surface is to apply a nice full coat over that of mailbox reflective paint that Rust-oleum makes. Have done a dozen or more using this method
I have done several sets with “chrome in a can” spray bomb after bead blasting,Also Eastwood exhaust paint is very shiny silver and I think I have used that too.
Thanks again AltaCat . I always thought that the 2357 bulbs were quite a bit higher amperage, but according to the specs that I just looked up they aren’t that much higher. Well down to the parts store to pick some up.
