Relay mounting wiring harness
I have 2 69 Cougars XR7’s. An early build and a late build. The early build relays are mounted on the cowl above the emergency brake and the late build’s relays are mounted by the left of the radio which is a much dryer and easy to get to spot. My question is if there are two different dash harnesses and if it’s worth the trouble to mount the relays and circuit breaker to the easier access spot. Thanks.
I guess I kinda jumped the gun upon further research I see there are 2 different under dash harnesses for the 69 and as to extending wires to relocate the relays and circuit breaker wouldn’t be feasible. End of thread.
