Rocker drip rail baffle question
Into the valve stem seal job on my 428 CJ, and learning a lot. One thing I noticed was that the baffle on the right was different from the left. The right has 3 holes at the base, but the the Left has no holes. Not sure which is correct, or perhaps they are both correct?
I’ve only ever seen the type marked R. Normally both are the same.
TY Royce. I have only ever seen this type marked as R or Right as well. So time to find another one for the Left side. I don’t think they are reproduced.
Maybe the one you have simply missed the drilling operation? I would just drill the missing holes.
Well, it isn’t just missing the holes. It is different in 3 ways: The holes are missing, the the leading edge that hooks over the rocker pedestals is different, and the notch on the one end is missing.
