Shock towers cracking
Just wondering if the 69 is prone to cracks or is it just the 68.
It can happen, But the factory added reinforcement plates to the shock towers to all 1969 Cougars. So if you have a cracking problem with a 69 or newer Cougar it indicates somebody rode it hard and put it away wet to many times. That said if the tower cracks haven’t separated, they can be welded up.
67-68 Cougars are prone to cracks in the shock towers? Where should I be looking? And where are the 69 reinforcement plates?
the reinforcements were added to help prevent this damage. I don’t have any pictures of a 1969 shock tower, but I do of a 1970. Thay are nearly the same. See the notes on the picture.
If you have any more questions, feel free to ask.
I had to edit this as I posted the wrong picture thefirst time.
Great diagram… that’s super helpful…
…and 67-68’s get those cracks? I’m guessing from cornering forces transmitted from the suspension to the shock towers?
Some of it is, but mostly lack of maintenance. When the upper A arms don’t get greased properly, they start to bind adding a lot of forces to them that they are not intended to take. 50+ years is a lot of time for things to happen to our Cougars.
The Boss 302 Chassis Modification book addresses much of this. 67-8s need an outboard reinforcement bracket, and stitch welding along the inboard seams, A rails and swaybar mounts.
Great recommendation… I’m going to get that book
At some point during 1968 production Mercury started adding reinforcement plates to big block Cougars.
The date appears to be some time in March of 1968. That’s when 390-4V Cougars and X codes started receiving them.
www.mustangtek.com/Library2/BOSS302ChassisMod.html
Reprints available. Think WCCC supplied mine.
Easiest start is a good quality export brace.
I believe I found the book on CJ Pony parts…
I noticed my shock tower braces are two-piece, so obviously a one-piece would be stiffer… what’s a quality export brace? The one from WCCC?
This is claimed to be a correct stamping:
https://www.summitracing.com/parts/SDK-C5ZZ16A052E
There are cheaper versions, like one I got in the 90’s. That was a shallower, broader ribbing.
If it won’t go directly on, jack up your front-end via the center of the crossmember, to try and get your shock towers to rotate outward a bit
This is one from WCCC,
Export Brace - BccLACK - PREMIUM - Repro ~ 1967 - 1970 Mercury Cougar / 1967 - 1970 Ford Mustang / Shelby ( 1967 Mercury Cougar, 1968 Mercury Cougar, 1969 Mercury Cougar, 1970 Mercury Cougar, 1967 Ford Mustang, 1968 Ford Mustang, 1969 Ford Mustang, 1970 Ford Mustang ) at West Coast Classic Cougar :: The Definitive 1967 - 1973 Mercury Cougar Parts Source
They have 3 versions of this. You can find the same one at NPD, Auto Krafters and others too.
Great, thanks! I saw WCCC sells a kit with the export brace and shock tower reinforcements… I think I’m going to go with that
Thanks for tip… super helpful
If you are economical like me and have a grinder or plasma and some scrap. Print this out to scale (measure the straight side)
