Short power steering hoses
Can you help a guy out?
I ordered a set of short hoses from WCCC.
The shorter of the two has a thick yellow stripe and the
longer hose has a thin yellow stripe.
#C6OA-3A714-A short
#C6OA-3A717-A longer
Does this look correct?
How do you know which end of the hose goes to the ram and which end to the valve?
Thanks,
Jim
Does this image help ? :
From Motor Trend January 02 2007
Also this:
The 3A717 is the upper hose in the pic GAH posted above, 3A714 is the lower.
Heres a pic from the Mfg of these hoses. Bluedot Specialties
Look carefully at the crimp part of the ends. They are stamped with CYL
Yes! Thank you, pictures always help.
Now I know which hose goes top/bottom.
As far as which end goes to the cylinder … I’m thinking the end with less
of a bend to it?
My plan is to build everything from the idler arm to the end of a new steering link
with new parts. Then remove all the old stuff and mount up the new unit.
Jim
