Tail lights on the 68 Cougar
Both bulbs closest to the license plate lights do not work so I attempted to pull them.
Are all the tail lights suppose to have the push on connector?
The drivers side bulb by the license plate light has an 1157 type socket.
How are you suppose to replace the bulbs? Do I have to pull the whole assembly?
Guys?
All 6 taillight/brake light bulbs and the 2 license plate bulbs are replaceable by popping the socket out of the rear of the taillight housing from inside the trunk. They are just pressed fit into place. You do not have to remove the taillight housing to replace any of the bulbs.
Why is one bulb different then the rest? It’s not a hacked up harness.
Six tail light bulbs should be same. WCCC has a bulb chart -1157 for tail light. Might be good time to consider LED replacements? With these old cars hard to say why somebody has put wrong parts in but usually because they were cheap or didn’t know better.
There are 8 lights in the tail panel. From left to right looking at the rear of the car, there are the three left hand 1157 tail lights, then two #97 bulbs (one on each side of the license plate), then three more 1157 lights for the right hand signals. The license plate lights are just sockets you pull out just like the other 6 tail light bulbs.
License Bulbs - 97 License Plate Light Bulb - Repro ~ 1967 - 1973 Mercury Cougar ( 1967 Mercury Cougar, 1968 Mercury Cougar, 1969 Mercury Cougar, 1970 Mercury Cougar, 1971 Mercury Cougar, 1972 Mercury Cougar, 1973 Mercury Cougar ) at West Coast Classic Cougar :: The Definitive 1967 - 1973 Mercury Cougar Parts Source
Tail light bulbs - Bulb - 1157 - Stop Lamp / Turn Signal Light - Interior / Exterior - New ~ 1967 - 1973 Mercury Cougar ( 1967 Mercury Cougar, 1968 Mercury Cougar, 1969 Mercury Cougar, 1970 Mercury Cougar, 1971 Mercury Cougar, 1972 Mercury Cougar, 1973 Mercury Cougar ) at West Coast Classic Cougar :: The Definitive 1967 - 1973 Mercury Cougar Parts Source
I’ll have to post a pic…
