The truth about dragsters... is
I know many of you have read this before but still…
Interesting facts about dragsters. Amazing that a motor can be built to endure such punishment; however, many of them don’t. What a ride that would be!
Acceleration Explained
  • One Top Fuel dragster outfitted with a 500 cubic-inch replica Dodge Hemi engine makes more horsepower (8,000 HP) than the first 4 rows of cars at NASCAR’s Daytona 500.
  • Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
  • A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster’s supercharger.
  • With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
  • At the stoichio metric 1.7:1 air/fuel mixture for nitro methane, the flame front temperature measures 7050 degrees F.
  • Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
  • Dual magnetos supply 44 amps to each spark plug - roughly the output of an electric arc welder in each cylinder.
  • Spark plug electrodes are totally consumed during a pass. After 1/2 way thru the run, the engine is ‘dieseling’ from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
  • If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with enough sufficient force to blow the cylinder heads off the block in pieces or split the block in half !!
  • Dragsters reach over 300 MPH +… before you have completed reading this sentence.
  • In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate at an average of over 4 Gs. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 Gs.
  • Top Fuel engines turn approximately 540 revolutions from light to light!
  • Including the burnout, the engine must only survive 900 revolutions under load.
  • The redline is actually quite high at 9500 RPM.
  • THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free, & NOTHING BLOWS UP, each run will cost an estimated $1,000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of t he run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 G forces at the starting line (nothing accelerates faster on land)
6 negative G forces upon deployment of twin 'chutes at 300 MPH
An NHRA Top Fuel Dragster accelerates more quickly than any other land vehicle on earth… quicker than a jet fighter plane… quicker than the space shuttle… or even snapping your fingers!!
The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta).
The top speed record is 337.58 MPH as measured over the last 66’ of the run (2005, Tony Schumacher).
Let’s now put this all into perspective:
Imagine this: You are driving a new $140,000 Lingenfelter twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged & ready to ‘launch’ down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line, passing the parked dragster at an honest 200 MPH… The ‘tree’ goes green for both of you at that exact moment.
The dragster departs & starts after you. You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutal, screaming whine that sears and pummels your eardrums. Within a mere 3 seconds the dragster effortlessly catches
& passes you. He beats you to the finish line, a quarter-mile away from where you just passed him.
Think about it – from a standing start, the dragster had spotted you 200 MPH… and it not only caught you, but nearly blasted you off the planet when it passed you within a mere 1320 foot long race !!!
That, my friends, is acceleration."
Blessed mother, don’t fail us now!!! (of acceleration)
been looking forward to the Snake & Mongoo$e movie showing up around here. Saw them race back in the day at Tulsa international. Love the drag racing.
Awesome, thanks Bill
Bill can you clarify the following two statements?: (Edit: think I figured it out)
The starting line tree lights? Edit: Okay, I think I get it. 9500 RPM is 158 RPS, so start to finish would be 3.41 seconds. Probably not a good number but I get the idea.
More confused about this one. Edit: Think I get this one too (now). So the burnout is about 5.69 seconds long using the numbers given.
Love the engine operation details! Almost solid fuel? Spark plug electrodes burned off halfway down the track? Awesome!
Thanks Bob. When I first saw the title and noticed you were the last poster, I was reluctant to read the thread. With the word “drag” in the title I was expecting to see the picture of the transvestite drag queen that you make us look at. Glad to not see that pic. Unfortunately, that image came to mind when reading the title of this thread. I need to do a better job of blocking it out. I really, really do.
Eye bleach. Only thing that’ll knock that image out. Mental image…I suggest hypnotic regression to just before the first time you saw said image. :shudder:
LOL Mark, that’s funny. Sorry to have given you such shell shock! I have merely continued to carry SoCalCraigster’s torch to seek out and respond whenever a certain shortened slang form of the word transmission is used.
Come to think of it, I think given your business, you could help stamp out the improper use of this slang word as well! How about a giant poster of “it” hanging in your shop with a title of “There’s Something Wrong With Your WHAT???”
Surprisingly, there are a lot of people that use the word tranny and don’t make the connection to transvestite. I don’t want to educate them on the second meaning by putting up a billboard with that guy’s(?) picture. I don’t like the term “tranny” but I’ll just quietly keep sweeping it under the rug.
Where’s the fun in that? :buck:
Not when people call me the “tranny guy” for owning a transmission shop. Let me clarify, owning a transmission shop IS the only reason people would call me a tranny guy.
Back to the initial topic…yeah, wow, cool, I guess they don’t care about mileage in a top fuel dragster.
Speaking of blowing up.
Ron Capps did up in Brainard over the weekend.
You could tell in the interview afterward that it scared him, just a little.
https://www.youtube.com/watch?v=tVKjccmpeu8
Wonder what kind of TRANNY they use in DRAGster’s?
Um…a stick? LMAO
A good vid on you tube :ylsuper:
Look at the intensity of the camera man as he tries to capture what kind of tranny is being used in that dragster.
Remember the Seinfeld episode where Kramer got the proctologist plate “ass man”. You should check with the DMV Mark and see if “tranny guy “ is available. :flushme:
Here you go.
That would get some attention.
I would like to second Mark getting this license plate.
Wait.
This isn’t the ROTM forum.
Nevermind.
Would you want me to show up at the next Cougar show dressed like that and with the Howard Stern wig?
