Can anyone tell me how to remove the top knuckle on my tilt away column? It is a 1967 Mustang tilt away column. The column is out of the car and I have the steering wheel removed and the top outer cover and I removed the spring and clip. I know I need to pull the two pivot pins but the tilt locking levers and still in place and I thonk they should be removed first before pulling the pivot pins.Can anyone post a how to list step by step? Thank you all in advance
