Does anyone know if BF Goodrich Radial T/A’s are still be produced in 14 inch ?
Thanks
Jeff
Thanks
Jeff
Did you try their web site ?
Yes, in several sizes. Not having the list of sizes in front of me I don’t recall them.
Available from Summit, Jeg’s(?), Coker Tire etc. www.tires-easy.com has a wide selection as I recall.
The BFG Radial T/A is a beautiful tire.
Sadly, it sits squarely at the intersection of great looks & abysmal traction.
No wet traction, no dry traction. If that isn’t bad enough, they don’t have the decency to give the driver a little squealing or howling before they break loose. Everything is just fine and normal right up to the second you start going going sideways. And I’m not taking about driving like maniac either.
If your only driving is in the 4th of July parade, then fine. Otherwise steer clear, imho.
Z
