Hey what do you guys recommend for a transmission oil pan? C4. The PO over tightened the bolts, I have tried to straighten it but I still get a leak. Tried to seal it a few different times. Unless you have some tricks to seal these things up, that’d be great to. Kind of frustrated with it at this point. Thanks!
A good used one!
Found a new Scott Drake one on google for $20.
https://www.cjponyparts.com/scott-drake-transmission-pan-deep-gray-without-drain-plug-c4/p/ATP10/?year=1979&gclid=EAIaIQobChMI47bJj63I1gIVSGSGCh1QdAFiEAQYASABEgLbO_D_BwE
There are also cast aluminum ones if you want a thicker flange to resist warping it, but they are $130.
