Underside of 1970 mercury cougar convertible
does anyone have pictures of the bottom of a 1970 mercury cougar convertible. specifically looking at the frame rails
Guessing your asking about rear frame rails.
If its the front frame rails firewall rearward were sprayed at a different time and station than from the firewall rearward.
Any detail that your specifically looking for? For rear frame rail finishes will be different depending on the angle and location but should be pretty much the same as Mustangs built during the same time period. Only difference I can think of is the location of the rear dolly pad that would not have been used and the shadow location on the rear part of the rear frame rail.
Have 100’s of pictures from unrestored 70 Dearborn Mustangs of these details. Shared the same line, painters, products and processes. Might help if we knew when the car was completed so we can look at cars hopefully close to your cars production period.
Not sure if this is what you’re looking for but if you need specific pictures, I may have some.
lookin for pictures from the front wheel are to the back of the door
thanks
this first picture gives me a pretty good idea of what i needed to see
thank you all
Don’t have a bunch of pictures from convertibles but here are some I hope will answer what ever question you have.
A couple from 69 Dearborn. Should be pretty much the same for most of the details.
