WCCC Solid State vs. Mustang Project Sequencer?
What are the differences here? Pros/Cons of each? Will the WCCC one drive LED’s ok? (obviously, pricing is a difference)
Mustang Project:
http://www.mustangproject.com/ProductDisplay.aspx?ID=cd701eed-c0ab-42ca-966d-de0448f2effa
WCCC:
http://www2.cougarpartscatalog.com/67w13a366.html
Anybody know of, or done a comparison between the two?
Thanks!
(Vic, would love to hear you chime in on this!)
Solid state devices don’t survive an EMP, so, you probably wanna factor that in. :stuck_out_tongue_winking_eye:
LOL, good point, Scott.
Seriously, though, nobody? Don Rush? Surely you have compared the two units?
Here are my observations based information from the Mustang Project website and previously published installation instructions:
CU: Cougars Unlimited sequential turn signal products sold by WCCC
MP: Mustang Project
  1. Does the system work with 1157/2357 and LED bulbs?
CU: YES, it will work with both LEDs and 1157/2357 bulbs.
MP: NO, only LEDs.
  1. Does the system use factory style connectors for easy installation?
CU: YES, custom-molded connectors matching the factory specs are provided - it just plugs in.
MP: NO, uses trailer tap connectors that permanently crimp onto the harness.
  1. Does the system use factory wire colors and wire gauge size specifications?
CU: YES, uses the factory color coded wiring and wire sizes.
MP: NO, wiring is sized for LED use only.
  1. Is the product made in the USA?
CU: YES, these products are designed and assembled here in the USA.The key components are manufactured in the USA.
MP: ???, no country of origin information is provided on the website.
  1. Does the system have a mounting bracket?
CU: YES, the bracket mounts to the original rubber pad in the trunk for vibration isolation.
MP: NO, wire ties are used.
  1. Is the system designed to meet SAE J1113 load dump environment?
CU: YES, the designs are tested using an 80V load dump simulator to SAE J1113 specs.
Load dump spikes are common in the early Cougars. The circuit will shut down if a load dump spike is detected.
MP: ???, no compliance information is on their website.
  1. Is the system protected against reverse battery hookup?
CU: YES, reverse hookup protection is provided.
MP: ???, no information is available.
  1. Are the outputs protected against short circuits?
CU: YES, the system will shut down if a short circuit to ground is detected.
  1. Does the Kit includes LED bulbs?
CU: NO, LED bulbs are available from many suppliers.
MP: YES
I have the older style MP sequencer “bulbs” system. Perfect if you are using a totally brand new wiring setup, such as a mustang Ron Francis style for a 68 for example, uses normal wiring techniques, as in brake, turn signal and lights on…simple. But , do they “click” when turn signals are activated, mine didn’t, so I added an old turn signal flasher for the clicking sound.
Just installed mine from WCCC. Works great. So much better than before.
Thanks for the input, fellers!
Actually I have not had one in hand. If the price was close I suppose customers would ask but until you mentioned it I had forgot there even was an alternative. Years ago they called me wanting me to sell it for them but after a quick review I decided there was no benefit to it over the tried and true unit Vic has offered for decades. Thanks for chiming in Vic!
Thanks, Don, and Vic. Appreciate the input from all.
