What plugs into this?
This is the wire harness for the clock and the 2 lights for a 69 XR7. The part number on the harness is C9ZB-15A006-B. The wires I have in my hand go to the clock and the 2 lights. My question is, what does this connector go to? It looks to have 2 black wires go to one side, and then black/blue and green/yellow go to the other side. I could not find anything in my wiring diagram I have. I don’t think it goes to the map light as I know what connector that is. Does anyone have any input or ideas?
Thanks
http://s1248.photobucket.com/user/mnkybrs/media/IMG_23761.jpg.html?sort=3&o=1
http://s1248.photobucket.com/user/mnkybrs/media/IMG_23771.jpg.html?sort=3&o=0
At the time wire harnesses came with all sorts of plugs for different accessories. The plugs still remained despite some of the options not making to the final build. All our cars have plugs hanging under the dash. The '68 wiring diagram does not give all the XR7 options. Just the base model. '69 diagram might be the same way.
Hi,
Did some checking, part number C9ZB-15A006-B is the wiring harness for the cluster clock. The clock in the gage cluster. Maybe someone moved it to the passenger side for some reason? Is this a standard or XR-7 model? Not sure I answered your question, but hope it helped.
Yes, that part number is for the clock harness. I took that number right off the harness. I have an XR7 and the clock is on the passenger side. I am thinking that maybe the harness is kind of a universal harness for Cougars and Mustangs and maybe something from a Mustang plugs into that connector. I just don’t know. As long as it works for me I am OK with it. I am sending out my clock to Rocketman tomorrow to get fixed. Thanks for checking and looking into it Trixie.
I had my 69 xr7 apart last winter and found a plug in that group of wires by the clock. If I remember correctly I found that it powered something with the convertible top. I do remember correctly that I did not use it. All of my power “stuff” still works in the dash with out it plugged in to anything.
I have a 69 XR7 convertible and I too have that extra plug just hanging behind the clock. Not sure what it might be used for but everything on my car works and the only options I don’t have are speed control and intermittent wipers.
Thanks. I was sure it was not used, but just wanted validation. All my options were working before I took apart the dash to work on my instruments lights which were not working. I will get it back together as soon as I get guages back from Rocketman. Hopefully the instrument lights will work.
