What the heck is this thing?
Found behind dash pad above glove compartment.
It’s a light i can’t tell from the picture if it is for the glove box or the one that goes into the shifter to illuminate the PRNDL. Is it plugged into the harness?
It is the glove box light. See the small bracket above the glove box door? That should be attached to the housing your holding.
Yes, shroud or diffuser that goes over the bulbs.
Awesome thank you guys. I just replaced my instrument bulbs with led kit.
Found a piece of construction paper that had Hampshire rubber co printed on it dated 4/21/0. I took a pic but It was blurry and I didn’t know until after I buttoned it back up.
The LED look great except I must have screwed something up cause now my fuel gauge won’t work??
Hampshire rubber co is the dashpad supplier.
The history of this car is cool to see.
