Could anyone please tell me the specs for wheel aligment on a 68. The tire shop computer database does not have them. Thanks
AJ,
I personally would go to another shop that knows how to work on these cars. You will want to run as much Caster as possible. Below are the min max and optimal settings from the Factory Manual.
min max optimal
Caster (degrees) -3/4 +1 1/4 +1
Camber (degrees) +1/4 +1 3/4 +1
Toe In (inches) 1/16 5/16 3/16
If you have power steering, you will want to make sure that they align the car with the engine running.
Hope this helps.
Coach Jack
Very helpful thanks. The tire guys aligned to spec by the car pulled to the right. They thought maybe the power steering needed adjusting but your last comment suggests otherwise.
