Wheel stud replacement on Wilwood disc brakes
Official reply from Wilwood regarding my particular brake kit.
Thank you for the inquiry with Wilwood Disc Brakes.
We’re sorry to hear that happened. Unfortunately this particular kit uses press-in wheel studs that are a one-time seat into the rotors; they cannot be changed once they’re pressed into the rotor. We have found that if the original studs are pressed out, the material/knurls of the rotor can become weakened, so the new studs may not hold the proper amount of torque. As such, you will need to purchase a new rotor if the studs are damaged beyond repair.
Classic series rotors for 140-13476 kit
http://www.wilwood.com/Rotors/RotorProd.aspx?itemno=160-13481\
Regards,
Wilwood Disc Brakes
