Where do I find the neutral start switch and back up lights wiring?
I’ve got a 67 Standard, but at some point a previous owner swapped in an AOD. However, he never hooked up the neutral start switch or the backup lights. I’ve got the plug with wires for the AOD side of things, where under the car do I look to find the stock harness to connect it up? I thought there would be an obvious plug hanging there, but I’m not really seeing anything. Any ideas what color the leads are and where they should be?
The neutral start switch was on the C4 originally. The wires probably left with it. The four wire plug is on the firewall I believe.
According to this https://www.stangnet.com/mustang-forums/threads/aod-neutral-safety-switch.657683/ There is an adapter cable from Ron Morris available.
Thanks. I’ll check across the firewall again and see if I can find anything that looks likely.
