Wire pigtail identification
I was moving tubs of parts around and this wire pigtail fell out. Can anyone identify it and where it’s home is? 70 XR7
There’s only one place that the 90* spade connectors are used in the underdash area: the brake switch connector. What you have there is not a factory spade connector either, but was pulled from some other car/model/make. The brake switch connectors are green and green/red wires.
The other, more likely, possibility is that is a ground wire for one of the tail light sockets.
