Those plugs are all over the place - hard to condemn a carburetor for that.
Seeing those plugs, I’d continue down the compression and air leak down test path if for no other reason to check the box (confidence builder). It is well worth the couple of hours it will take (goes fairly quickly once you get started assuming you have adequate access).
The compression test came back with some interesting results.
- I can hear air escaping from somewhere underneath the car.
- Still had air coming from the oil dipstick.
- Ive got 2 cylinders that were well below 10% tolerance.
All of these, combined with the original cooling issue are making me think that ive got a blown head gasket and it might just be time to have the engine rebuilt.
It’s not abnormal to hear air escaping into the crankcase as long as compression and leakdown tests are good. That is called blow-by, and is the reason the crankcase has to be vented through a draft tube or through the positive crankcase ventilation (PCV) system.
That said, the sound should be uniform between all cylinders. Leaking out from under the car, or louder on certain cylinders is not right. That along with your bad numbers on two cylinders, plugs being all over the place, and your original problems would make me want to open the engine up for a refresh too. Dieseling can be a sign of excess carbon build up, which is evident on several of your plugs.
I nursed mine along with leaky valve guides, drips, and overheating problems for far too long before I finally pulled it and made everything right. You could tell mine had low compression on certain cylinders when you cranked it with the starter. The starter didn’t have uniform resistance and sounded uneven. Kind of an “r-r-skip-r-r-r-r-skip” sound. It runs so much better now, and can finally be trusted to drive too!
That is exactly what mine sounds like on start up now. So I think just getting it professionally redone is the best call.
If by any chance anyone has used Strang Enterprises out of NC id be curious to hear about your experience.
They come highly recommend but you never know.
