1970 351c Cooling issues
So it is absolutely possible that sealant broke free.
I recently bought an IR thermo to test the block it’s something I didnt think about originally. When it ran so well that one time I was hopeful it was done.
When I flushed the block I did have some sediment, but i flushed it till it ran clear. So it’s still possible I missed something.
When I went to test the IR thermo it wouldn’t start and the battery was super low. So that the next issue to address before I can verify the temp.
I also plan to run some seafoam in the block to hopefully remove any carbon deposits that might have built up. The diesling may have been an independent issue.
That makes sense and I agree. Its absolutely possible the guage just isn’t working properly.
Once I verify temp with the IR gun ill hopefully have a better idea.
Mine never ran clear after flushing, so hopefully yours doesn’t have that same problem!
After a close inspection, looks like the hose that connects to the thermostat was leaking slightly. Im guessing when the system was pressurized, the leak was worse and I didn’t notice because it was evaporating due to the heat.
I tightened everything back up and once the battery charges (ran into a low battery after the last drive and now it won’t turn over) ill verify with the IR gun and check the hoses again.
Plot twist, I have a new problem that may have been causing the cooling issues.
Got the car to crank normally by resecuring all electric components.
I decided to go through and just re verify that all connections were clean and right.
Didn’t see anything, but gave everything a healthy tighten. The slow crank issue stopped but opened up a whole new can of worms.
I went to start the car and it still wouldn’t start. I didnt want to flood the engine so after a few times I let it sit for about an hour.
After the hour I went to try again and it backfired. Sounded like it came from the carb.
Out of curiosity and concern I went throughthe forum and found a few threads about oil and fuel mixing due to a bad fuel pump causing some of my issues. I pulled the dip stick and the oil was abnormally high and smelled like fuel.
Im thinking also that this may have been going on for a while and may be why my engine was running hot and dieseling sometimes
May be unrelated but the ethanol based fuels are not kind to these old cars.
Any sense of how old the pump is?
The pump dates to April of 2011. So that makes sense that it would fail.
Additionally, now that ive pulled the pump, the intake or outlet isn’t holding or pushing vacuum.
Fuel was still making its way to the carb, but I absolutely had fuel in the oil. So im thinking diaphragm failure.
The only thing thats odd is the weep hole isn’t wet.
Looks like you’re due for a pump.
Seem to recall seeing ethanol compatible fuel pumps advertised but haven’t specifically gone looking for one and have no experience with them.
Good thing it’s a fairly minor repair so you can get back to driving the beautiful car.
My only concern now is that ill have trace amounts of fuel in the oil even after I add new oil.
Im sure there isn’t a way to 100 percent clean it out. But im hoping it won’t be an issue.
I don’t know that you’d have enough residual to worry about.
Maybe leave the drain plug out, remove the valve cover breather and PCV and just give it a bit of time to evaporate if it eases your mind.
So it was really bothering me that despite the fuel pump intake and outlet feeling weak, there was no fuel at the weep hole.
So i took the pump apart to look at the rubber. For a 15 year old pump, it doesn’t look bad.
So while im glad im getting the experience of changing it out, im concerned im missing the overall source of fuel getting into the oil.
For context, it was extremely noticeable when I drained it.
Im running an edelbrock avs2 carb that I tuned in the dead of summer.
Im guessing the options are:
  1. The fuel pump was the problem and while the leak was small, over time it accumulated.
  2. im running extremely rich and need to dial in the carb.
  3. When I was trying to start her after my cooling issues, I flooded the carb so much that it flooded the engine to the point fuel was leaking past the piston rings.
  4. Its leaking past the piston rings regardless and ive got a bigger issue on my hands.
Currently im planning on opening up the breather and letting it air out over the next day and a half.
ill get the new pump on and put clean oil in it.
when I try to start it again, ill choke off both air and fuel and open up half turns until I can get ignition.
I didn’t see any mention of flooding or drivability issues suggesting uncontrolled carburetor leakage isn’t present but inspection/observation while running will answer.
An air leak down test is best for answering (4) above.
Well, if the pump won’t pull a vacuum, it needs replaced regardless. But also, backfiring through the carb can be a sign of severe flooding. And gas in liquid form could find its way through the gaps in the piston rings. You might be getting gas in the oil from both the fuel pump and the carb.
This has really turned into to a soul journey.
Ive got the new fuel pump in. The old one left absolutely no gasket residue. Which seemed odd. The instructions on new one had me put sealant on both sides. Wondering if that was apart of the issue.
Ive got new oil in, and tomorrow ill do a cylinder leak test.
Hopefully all of this is just overkill and it was the fuel pump.
The fuel pump gasket is there to keep the oil splashing around on the timing chain from leaking out at the base of the pump. It’s failure could cause oil to drip from the pump base, but wouldn’t cause fuel to leak into the oil or drivability issues. Good luck when you fire the engine back up again!
So i started my leak down test.
First cylinder I tested had air loss within a 10 percent range and I could hear air escaping from the oil dip stick.
The spark plug was also significantly covered in carbon.
So im obviously running rich, and have at least one set of weak piston rings. I’ll test the others to see.
The more meaningful test for you will be a comparison from cylinder to cylinder. If one is significantly worse, you will know where you have bad rings, a scored cylinder wall, or leaking valves. If they are all around 10%, you are in pretty good shape. It does sound like you are running rich.
Calicat,
I agree with you. First do a simple compression test followed up with a wet test. If warranted then do the leak down test. As an old school mechanic always go the easiest path first :grinning_face:
10% leakdown is absolutely fine. Once you get past 20% then you need to think about other options.
Ok, before I do the compression test on all the cylinders I figured id take the advice of looking at the most simple things first.
The issue recap:
car was running hot per the thermostat after running fine. When I turned it off after it getting that hot it dieseled and then wouldn’t start.
I discovered fuel in the oil. To the point it smelled like 2 stroke.
Oil drained and replaced, along with a new fuel pump.
Where im at now:
  1. I did a compression test on cylinder 5. It was within tolerance but i could hear air from the oil dipstick. The plug also looked like this:
This made me think that I was running rich. Before I made an assumption, I pulled the rest they look like this:
I know every little about how to read the tea leaves on these, but I do think im running rich. The ones that are wet are concerning though.
I think my car (edelbrock avs2) may need some adjustment.
