So, I was driving home yesterday in my 67 GT 390 Cougar from my buddies house and I pull onto one of the county routes, I noticed a noise. So I muted the radio and there was a fairly loud pinging noise every time I dipped into the peddle. I’ve never had any issue dropping the hammer on the car and I have been using middle grade octane gas for years. So here’s what lead me to this point and what I tried. Engine is stock 390 original bore. Was rebuilt at ~80K miles. Still has standard bore and currently 99K miles.
- I got the radiator re-cored this spring but have noticed the car had been running what I felt, hotter than in the past. Never over heating though
- I started noticing that the swing away was not as responsive when I opened the door and it would only work once. It works on vacuum and usually you get about 4-5 actuations before the can runs out of vacuum.
- Last Thursday when I got home I checked out the vacuum line under the column and noticed a crack at one end. I cut it and reinstalled it and tested but it still only did one actuation. So I went hunter the hood and disconnected it and plugged the manifold port.
- Started wondering if this might be why I was running hot since a vacuum leak could cause it.
- Temp gauge on Friday seemed better but it was also hard to tell since the temp in NY had dropped some.
- So then yesterday happens. The drive to my friend’s house was great. Car was running awesome.
- After noticing the pinging sound while driving, I put it into neutral and revved it and there was no pinging. Put it back into drive and rev it and sound was back. So I figured it isn’t coming from one of the accessories on the front of the engine.
- I ruled out the thought of bad gas since I didn’t get any recently and had driven plenty of miles with what was in the tank.
- So I retarded the timing some. No change.
- Filled it full of the highest octane no ethanol gas we have in town. No change.
- Drive today in was rough at times going up a couple of big hills we have. Down shifted to get the revs up which causes the load to lessen and pinging to stop. Cruising at 65 nothing seems wrong unless you hit the throttle hard.
I should also note, cold start fires right up and idles fine. Hoping someone might have some thoughts. Hope it’s something stupid.
Thank you,
Jim
