My footwell lights and rear C-pillar lights do not come on, when I open the door. Door panel lights work fine. I did just replace the headlight switch. Any thoughts on the best way to sort this out. I did use a 12v probe to test the socket for power, nada. I also twisted the headlight switch both ways, nada. ![]()
The problem is most likely in the center dash switch. Power to these lights comes through that switch. Here is some discussion on that, along with an easy suggested fix.
