Aloha!
First time poster, long time “ghoster.” To be frank, I lacked the vocabulary to engage intelligently. It took some (years of) nudging from friends to get me to understand part of owning an older car is to learn to enjoy maintaining and repairing it. So here we are.
Long story short, our '72 COUGAR convertible, a member of the family since March 1972, decided she no longer wanted to engage or stay in gear last June. We pushed the old girl home and found transmission fluid leaking into our car port.
I reattacked last weekend, degunking the underside, and inspecting all lines. We verified that all the mechanical linkages were sound other than the knock down rod which had come disconnected up near the carburetor. Reconnecting it did not lead to a round-island cruise. ![]()
I am blessed to have a knowledgeable mechanic at our local shop who works with these older cars. Better, he enjoys sharing his knowledge with routine customers. He suggested I inspect the hoses to the vacuum modulator. I found these were sound, and, after doing some Google-ing, I pulled the vacuum line off the modulator to look for leak-by. Nope. Dry as a bone.
Today’s inspection did show some weeping and I am assuming since the oil is clean this is seeping past the seals and not left over from June’s transmission fluid blow-out. I should note we ran the engine for 20 minutes the other day and tried shifting without recreating the Fountain of Fluid.
I also snapped a picture of this metal “pipe to nowhere” aft of the transmission.
I assumed that this was a high point vent, as there are no obvious places where a low pressure rubber hose would go from the end of this pipe. Would this have been the source of the Fountain of Fluid if the transmission had overheated, causing the oil to expand?
I next plan to take off the pan and inspect for metal shards the spell end-of-transmission, but I am out of time today. I appreciate the “vector check” on my approach to date and welcome all suggestions.
Thanks again for letting me join the ranks as a more active community participant.
Eric
P.S. I had a couple other photos. I can post those as I get site privileges.
