Apologies if this is posted elsewhere but where do I locate the casting number for a 428 Cobra Jet block? I did find the VIN numbers on the rear of the driver’s side cylinder head but I want to know if the block is also numbers matching. Where do I look. 1970 Cougar Eliminator, 428 CJ, 4-speed.
Externally with the engine in the car there is not any way to ID a 428 CJ block. The date code will tell you what day that block was cast, but the block could still be a 390. Or a 360. Or a352.
For your car the VIN was supposed to be stamped on the rear face of the block near the cylinder head mounting surface. If you carefully clean the area with solvent and a rag, then take a photo using a cell phone with the flash turned on, you MIGHT be lucky enough to see it. If you already found the VIN stamped on the block then you indeed are likely to have the original 428 the car was born with. I would take photos and keep the photos with the car for future reference.
It seems to be “9K31”; does that mean October 31, 1969? If so, that would be even more spooky as this car is called Project Freddy (Cougar, not Kruger) but the motor would have been cast on Halloween day in 1969?
Yeah, 9K31 would be a casting date of Oct 31st, 1969.
Compare that with the build date for your car on your Marti Report.
Looks like the block was swapped out at some point. Maybe a casualty of the racing history?
As far as I know, it is most definitely a casualty of the racing history. And now the big question is, “is that the same block that was in it when I bought it 50 years ago?” or has it been replaced again since I owned it? I plan on dropping the oil pan and seeing if it looks familiar on the inside. There are a few clues that would tell me if it is the same thing that I saw inside of it when it was newish.
There is no such thing as an SCJ block. All 428 blocks were identical. Some decame SCJ’s. Some became CJ’s. Some became cop cars. Some went into Colony Park wagons. Some went into T-Birds. Some went into LTD’s.
If you can show me a photo of what you are talking about I could likely explain it.
I’m going to say it was up side right to begin with. I think the guy on the foundry floor was in a rush and you can not erase a minor mistake. This proves it is a 428. The CJ comes from the heads more then anything else.
This is the “C” scratch on my 428PI.
I would say you have a CJ as you have the “N” heads and the correct intake. If I recall yours has headers instead of the correct exhaust manifolds. I think your good with this block.
All 428 blocks should have the big “C” scratch on the rear bulkhead sand cast mold starting about August 1967 and going until the end of production. Nothing special for the 428CJ or SCJ - it was all 428 engines whether they were for a cop car, a 428SCJ, a 428 CJ, or granny’s Colony Park 428-4V station wagon.
