I’m such a noob I still don’t know exactly what ping sounds like.
And you’re right, in addition to just checking the contacts out as a matter of course, this was actually part of trying to track down a bigger problem. And the problem is…
After filling her up with 93 octane yesterday, and then on the highway on the way home seeing if she doesn’t mind going over the speed limit (got up to 85 according to the iPhone speedometer app, around 4k rpm on the tach) then when I was on the surface roads on the way home I heard what sounded like ticking when I was sitting at stop lights at idle. I couldn’t hear it well, except reflected back at me off cars in the other lane or the side of buildings.
So I thought maybe this was ping, which I’ve heard of but don’t exactly know the sound of. YouTube searches didn’t do anything to help really. So I headed over to the garage tonight to fire her up and get a good listen, and then potentially drive over to the CarQuest to pick up some octane boost on the off chance that the gas station somehow got their low octane and high octane fuels mixed up.
Anyway, I got to the garage, fired her up, and though she’d crank fine, no signs of firing. Then I remembered that I’m an idiot, and since there is now a second car in the garage I rent, and they had left the door wide open during the day (facepalm), I did the cheap safety precaution of removing the wire from the coil to the distributor so nobody could steal it without bringing their own wire. Stupid me forgot to replace it before I fired her up.
So I replaced the wire and fired her up, and here’s what I was getting… Turning over and firing and starting up, but as soon as I’d return the key to the on position, total shutdown. I’m 90-something percent sure the reason behind that is the starter solenoid needs replaced, since after numerous attempts at starting I went ahead and tried the “hit the solenoid lightly with a hammer to un-stick it” trick which then resulted in the car finally running with the key in the on position but running very, very weak. And when I removed the solenoid to bring it home to test it out, I found that the “I” terminal on it was totally loose and could be pushed inside the housing if I let it fall in there. So, 90-something percent sure that thing needs replaced. I’m gonna do it Friday hopefully.
On the off chance that I put the distributor back in with the rotor rotated one position (which I highly doubt but have to consider) would that result in the engine running really weak, or not running at all? Or is it probably the solenoid not working properly?
From the pics, what needs done there? New rotor? New cap, or try and clean up the four dirty contacts on the existing one?
