Upgrading my stock Column to Flaming River tilt column, having an issue with the wiring.
Wires from column to female connector has 10 wires.
- Yellow - horn power I read somewhere
- Blue w/ yellow stripe - also read horn
- White w/ red stripe
- White w/ light blue stripe
- Green w/ white stripe
- Green w/ orange stripe
- Green
- Red
- Orange w/ blue stripe
- Blue
However, the male end of the pin connector to main harness has 11 wires
1.Yellow connects to yellow pin from above
2. Light blue w/yellow stripe connects to blue w/ yellow pin
3.green w/ red stripe connects with white w/ red stripe pin
4. Orange w/ black stripe connects with green w/ orange pin
5. Orange w/ black stripe connects with orange w/blue stripe
6. Orange w/ yellow stripe connects blue pin
7. Red connects with light blue pin
8. Green to blank pin
9. Green w/ white stripe connects to pin that has light green and white wires (2 wires)
10. White w/ light blue stripe connects to white w/ light blue wire and violet wire (2 wires)
The flaming river harness I have to splice into has only 8 wires, this is the harness the vendor said was for the 68 Cougar
- Black - horn
- Light blue - LF Turn signal
- Blue - RF Turn signal
- Brown - hazard power
- Purple - turn signal power
- Yellow - LR Turn signal
- Green - RR Turn signal
- White - brake light lower
I’ve downloaded the wiring diagram, but am admittedly making best guesses at it.
Any help wiring this up would be appreciated!
