Fordblue's 67 Coupe:
I got home today to find this:
By null at 2011-10-26
Here is where it came from:
What’s inside?
Here’s a hint:
The new (used) trans!!!
Yep late 60’s vent tube:
After the first round of pressure washing:
So, now for the next few days, I’ll be tearing this down and doing a full rebuild, bushings and all, plus the addition of better frictions and bands, and a shift kit.
I’ll take pictures all through the process until I have to poor girl back on the road and not leaving a red streak of transmission fluid behind her where ever she goes.
Still waiting on the torque converter to arrive any day. All I have to do is reuse my bell housing and some linkages.
I bet the UPS guy has a hernia! Just kidding of course. I tried to give my UPS guy a beer after delivering a “box of anvils” to me. Turns out they get fired on the spot if they get caught with a beer.
Where did you get the cart? That looks perfect for parts cleaning.
Its a Snap-On cart. its one of the many things I acquired from a friend who used to be a mechanic and owed me money. I have two of those carts, a huge Mac tools roll around tool box, and a twin post lift that is waiting for a bigger shed to be installed in.
The guy didn’t owe my a huge sum of money, just many medium unpaid loans where I got more and more of his stuff when he couldn’t repay which erased the debt and allowed him to “borrow” more money as need be.
The poor man’s part washer: Purple Power cleaner, water, and a bucket…
By null at 2011-10-27
The usual nastiness when tearing down the parts that can’t really drain well when the trans is in the car:
Overall, it looks like the trans was somewhat neglected, but not really abused. All the guts, minus a few thrust washers, the low/reverse servo and the parts being replaced by the rebuild parts I bought look like they can all go right back into service after cleaning and soaking in trans fluid a while.
And finally, after cleaning round 2. This is as clean as is it getting without some serious scrubbing and steam cleaning.
That was it for yesterday. Today will be individual component cleaning and inspection and running to Transtar after I figure out which thrust washers I will need.
Looks like it got warm a couple of times. How brittle are the seals?
I was surprised to find all the o rings in the clutches in good shape.
I am still changing all the thrust washers, bushing, and seals, orings, gaskets, etc while it is apart.
Today I got the clutches rebuilt, the pump gone through, and a few trips to transtar for parts, snap rings, etc.
Tomorrow should be a day of progress where parts start going back in the case.
Great pictures. I have seen much worse rebuild and work like new. Keep up the great job. Be sure to soak the clutch discs over night in transmission fluid.
Cool thread. I didn’t realize you could ship a transmission by UPS.
I am sure glad you said “transmission” and not “tranny”!
Toeing the line, there mister! :laughing:
I’ve purposely been trying to say “transmission” or “trans” in place of “tranny” just to avoid that mental image, lol.
I am at a stopping point at the moment. I have to wait till Monday to order the thickest snap ring for the forward clutch pack. My clearance is already at the far end of the allowance, so any wear will put it out of spec and I can’t add another plate to the pack to take up slack, so that is my only option for now.
After that, the rest of the reassembly should go smooth. The end play of the input shaft should be between .008" and .042", and before tearing mine apart, it was about .085", so hopefully the thicker thrust bearings should take up that slack when its back together for more measuring.
Hopefully Transtar can get that snap ring to the local warehouse asap.
Didn’t want to risk Craig showing up with that hideous image!
The discs get a little thicker when they soak in ATF. Did you soak them first? If the spec you have is for a dry disc then disregard what I am telling you.
Yeah, that measurement was taken with the disks already haven soaked for a day. Just gotta find the hard to find snap ring.
Thanks
Snap ring ordered today. Will be delivered to the house tomorrow.
Snap ring arrived and installed. Forward clutch clearance now .031"
Progress may now resume.
That is all.
The trans will get some more work done tomorrow. I had a delay of game with another project. Our boat has been under renovation. It has gone from this:
By null at 2011-10-31
to this:
And, the last few days have been filled with this:
https://www.youtube.com/embed/j0FWsfSifR4
So, now that the weekend is here, I get to stay home and do some work dedicated to the car.
Dude! Nice Boat! What are you going to power it with?
The 3208 Cat that’s in the youtube video. 375HP at 2800 RPM. We built that cabin from scratch out of 2" thick foam board with a LOT of fiberglass on it.
Okay, finally got back to the transmission today.
Got all the guts reinstalled, valve body rebuilt with “reprogramming kit” from Transgo, all the air checks done and the bands and clutches are working like they should. Got the final assembly wrapped up as much as can be without pulling out my current trans out to get its bellhousing and shift linkages to put onto this one:
By null at 2011-11-08
Got servo cover painted, as that was my one gripe about the transmission, the plain steel cover in it looking out of place:
Installed the filter, put a magnet in the pan, installed the AN fittings to run hoses instead of hard lines to the cooler(s), adjusted the bands and put the locking nuts on the adjuster and put the modulator valve in after this picture was taken:
The wrenches on the front were put on the bolts to take up the slack that the bell housing usually does so I could torque the pump bolts and check end play.
I luckily guessed correctly on my select fit thrust washers. End play should be .008" to .040" When I started, the trans had .080" end play, and when I got it put back together today, it measured out to .015" on the first try. So, I have room for things to break in, the new thrust washers to wear down a little, and it still be in spec.
That little Makita 18V impact driver is a life saver for disassembly and reassembly. With the variable trigger, you can snug up bolts until it stalls out, but before it starts to hammer like an impact, and that is below any torque spec on the trans. That way you can come back later with the torque wrench and make sure it is all correct.
It is supposed to rain and get cold again tomorrow, so that will dictate if the current transmission comes out of the car tomorrow.
