So it begins…
By null at 2011-11-09
Luckily, last time, I left the exhaust clamps loose, so that came out on about 5 minutes. The gods of car disassembly were with me today, in a hour, I had all parts out of the way and the transmission ready to drop out. Got the original transmission out, and immediately found the source of my leak. The bolts holding the pump and bell housing to the case were only finger tight. This is why I am no longer letting helpers work on the car when it comes to major projects.
Anyway, swapped the bell housing and the linkages over and amazingly, I guessed right on which way the shafts went in when putting it together.
Okay, I need the Navajo Code Talkers of Ford p/n’s to decode this for me:
And yes, I fixed those leaking valve covers already.
Here she is, all purdied up and ready to go in the car:
Reassembly went about the same as disassemby. Fairly smooth and uneventful except for when I drove my knee cap into the body seam running under the passenger side of the car. I thought I split in half like a piece of fire wood upon initial impact. Amazingly, no blood loss.
Got the H pipe back on the car and fired it up. let it idle for a minute, put it in gear and… nothing.
Then I remembered I put a 2400 stall converter in the car, revved it a little and it has reverse!!!
Put it in drive, the wheels go forward.
At first, the shifts are pretty harsh and doesn’t want to go into 3rd gear.
After running a while, the shifts soften up and it now runs through all 3 gears on its own, sweet.
I hop in the truck, run to the store, get 4 more quarts of fluid, restart the car.
Pulled the dip stick and can hear a sucking noise from the tube, so I know its low on fluid. Add 2.5 more quarts of fluid, reading right at full on the dipstick and no more sucking noise.
Drop the car in gear and the shift are back to being harsh again, so the pump and shift kit are doing their jobs.
Now, the car is not wanting to shift automatically, I can drop it in 1, run it up to 20 MPH, shift it to 2nd, shifts like a dream, put it into Drive, and no 3rd gear again…
I hope that maybe it just needs to time to sort itself out, so I drop the car off the stands, and decide to go for a quick spin in the rapidly setting sun.
Its driving the same, can shift manually with no problem, but no 3rd gear. It has reverse, low, and 2nd, so all the hard parts are working, I just have maybe a mix of modulator adjustment and valve body glitches.
When I shift from 2nd to D, the car revs like it is over running a clutch. Can a really misadjusted modulator cause this? Or am I pulling the valve body back out?
I put all the check balls, springs, and other mods the shift kit called for in correctly, I made sure of this, I have had the “missing check ball” shift problems before, so I made sure to avoid that this time around.
Of course, between the cross member being right behind the modulator and the exhaust being right along side it, I couldn’t do any adjusting today, as it was dark when I got the car back in the driveway.
Tomorrow it continues…
