I am replacing upper and lower control arms on a 1970 cougar Xr7. I am not to sure what the name of the above particular suspension is, does anyone know?
Also, the second picture is the same suspension piece from a 67-70 mustang bushing replacement kits. I was going to use it but the steel sleeve between the bushing are different lengths. Will that matter? Or create issues with the suspension?
From a technical point of view, you would need to go the shorter sway bar links and bushes as per factory. In fact you would use shorter sway bar links if lowering a car.
But no one ever shortens their sway bar links when they lower their car. It’s just not worth the effort.
The only reason to retain the original sway bar link length is so bushes wear evenly.
A subtle change in length is not going to affect the suspension.
If you are not obsessed with originality, I would run what you got, even the longer sway bar links.
I am using front coil springs with a 1” drop from WCCC. How much shorter shoulder that sleeve be to lower the linkage to account for the 1” drop? I am also planning to put a 1” sway bar on to help stiffen up the suspension, will that affect this issue?
All that and so much more stuff that you will need can be found in the 1970 Car Shop Manual (5 volumes). Readily available in both paper and digital formats. I prefer paper since I seldom have my computer under the car with me.
Did you put a shorter sleeve on there? It also look like you increased the thickness of the sway bar, is that correct? Did the thicker sway bar help with stabilization? Did you notice a difference?
1 1/8 in front 3/4" Stambar adjustable in the rear. Shelby drop, Upper A arm correction & reinforcement to arm. Roller spring perches, Modified 70 spindles for bump steer. Xport & reinforced crossmember.
You want your end links to be vertical. Addco, who makes virtually nothing but sway bars, recommends no more than a 20-degree variation from vertical. If you have too much cant on your end link then vertical motion of your lower control arm will cause the end link to pull/push the end of you sway bar forward and aft which may accelerate wear on the sway bar center bushings.
After lowering my car, the end of my sway bar needed to be tilted upward quite a bit in order to get the eye on the end of the bar directly above the mounting point on the lower arm. I solved the issue of distorting the end link bushings by grinding complementary angles in the bushings that go on the sway bar end of the link. Prothane has a variety of universal polyurethane end link bushings, and you can easily modify polyurethane by sanding it. Use a belt or disc sander, even a bandfile.
You can also make your own end links in order to get any length you want. Just get some Grade 8 3/8" threaded rod and some thick washers. If your sway bar permits you could go to 7/16". You can double nut the nuts on either side of the bushings or use locking hardware and you won’t need the sleeves. A wide variety of high quality hardware is available at McMaster& Carr (mcmaster.com).
The reason to remove the sleeve was due to the modified front end stance. It has the 1" Shelby" drop, the upper A-arms were bent, and the springs were cut by 1 1/2 coils. Time tested on the track, and dialed in over a few years.
The front diameter was I believe was factory 3/4, upgrade was 15/16". I went to a 1 1/8 thus needing a rear. I ended up with"Stambar" as it was adjustable. It is on the lightest setting so maybe I could have gone smaller, but it works so well!
