Got some work done today over at dude’s awesome garage.
Tried to install his fan shroud. No dice. It’s a 20" shroud, stock from his '70 Mach I. The shroud would fit fine, the holes all like up. But the neck up at the top is in the wrong spot. My neck is 4.5" on center, in from the edge of the radiator, his radiator and shroud have it at 3" in from the edge. Can anybody confirm what is correct for a 68 20" radiator? Since he believes his to be stock, and mine is missing the shroud that sorta suggests mine is a not exactly correct aftermarket 20" radiator.
Then we moved on to the valve cover replacement. Took forever to scrape all that gasket crap off the heads. Ugh. The cork gaskets came off easy, just that gasket sealer sucked. Eventually got it all off and put the new valve covers on, used the rubber gaskets, used no sealant of any sort, just got em on and lined up and bolted down. No signs of leaking, and they look great. And for the first time since I’ve owned this car there is a hose from the oil filler cap to the air cleaner.
Didn’t end up using the new PCV valve I bought, the guys both felt that it was garbage and I was better off keeping the existing one, nice heavy duty Autolite one that works. So stuck with what I had there. Replaced the hose though, with some heater hose, as the hose that was on there didn’t really fit well with the new, shorter valve covers.
Then we replaced my points with the Ignitor II that dude had. That went easily enough. Checked the timing. Way off. When I had last checked it, just a few weeks ago, it was at 6*. After putting in the Ignitor II it was at 20*. We moved it back to 6* and it was running great. Then the idle…
Last year I had bought a digital timing light/tach and set my idle by kinda balancing the readings from that with the readings from my factory tach, which were wildly off from each other. I ended up leaning toward the factory tach since that made for a smoother idle. Well since then that tach died, and both guys agreed that she sounded like she was idling too fast. So we brought it down from around 1050 to 700, according to that digital tach anyway. I’m gonna check it with mine and see if they agree.
Then the last thing we tackled was running the vac line through the firewall to my vac gauge that I mounted in place of the clock. After about 6 months of that console pad piece sitting in the back seat with the gauge mounted to it, it’s finally in place and working like a champ.
Around 18.5 at idle and cruising at 25 mph, around 15 on the highway, around 22-23 when decelerating. And around 0 when I floor it.
In the process of running that like, we pillaged a hole that was being used for a wire… Turns out that switch under the dash that didn’t seem to do anything except light up (the switch) when in one position? Was wired to the light on the underside of the hood. The light that never worked, even though the bulb was fine. D’oh!!! So we snipped that wire, brought it under the dash, and used that hole/grommet for my vac line. Success!!
Other than the fan shroud, everything turned out pretty great. Oh and both of them suggested I take the car to a mechanic they use for jobs they can’t or don’t wanna tackle themselves. After rotating the tires when I painted em, one that came from the front to the back just a week or two ago already has the same fluid wetness/drip lines that both rear wheels had before. The axle seals definitely are still leaking. And that can’t be good news for the rear end. So I’m gonna just go ahead and have their guy take care of that, should be quick, reasonably priced, and properly executed. Fingers crossed.
So that will leave the power steering and front suspension rebuilds yet to come, gotta pick up some parts for both still, and also the tank and lines which I’ll try and tackle as soon as I can. Maybe this week.
Is there an actual light at the end of the tunnel? So weird. Well, there’s always new tires too. Lining up the PRNDL which is off by about half a position (Bill??). Installing my new (Christmas) stereo if I ever get Cougar replacement pieces for the Mustang ones it came with (Don???). Fixing the horns. Cleaning the carb. Headlight motors.
Yeah who’m I kidding.
