So after pulling off the first wheel to embark down the road of rim painting, I figured I might as well snap some pics while that’s all opened up and all. Get some feedback on what looks like trouble.
So without further ado!
Some things jumped out at me.
Not sure what they’re called but those adjustable brackets on the coil-- on the passenger side wheel they’re installed like I woulda thought, used to keep the coil slightly compressed in one spot. On this side, driver’s, it’s installed reversed, so it would prevent the coil from compressing in one spot. It’s not even in there tightly, which I assume is because it’s on jack stands so no weight on it. So is that in any way reasonable? My gut says no. Then again the car does seem to sit level, so I dunno.
Another thing, the disc looks kinda haggard. There’s that one really ugly spot you can see in the pic. I ran my fingers all around on the disc and it feels totally smooth everywhere. But visually it just looks scored. The brakes work great as far as I can tell. Totally happy with their performance. Any issue here? And you can see the thickness of the pads, which looks plenty thick to me but what the hell do I know? The way it sits, the hub doesn’t rotate totally freely, though with just a tiny bit of muscle I can rotate it just fine, but there’s clearly some drag of the pads on the disc. That proper?
I see some bushings that look a little crackly on the edges but felt solid when I squeezed them with my fingers. Probably a case of “replace em and be blown away by the improvement in handling” there? Necessary, a “nice to have”, or no big deal?
And then you can’t see this in the pics, but the vacuum tank (which looks really nice) doesn’t even have a line running to it in the first place. No cruise control or tilt wheel, just PB and dist vac advance in play. No need for the tank, right? Should I pull it off to save weight? Sell it if it tests good on the mityvac? Run a line and hook it up? Forget all about it?
How’s that rust up at the underside of the top of the shock tower? Not so bad? Seems inconsequential to me but I know rusted shock towers are an issue to keep an eye on.
Anything else? Anything jump out at anyone, something that could stand to be addressed or especially anything critically important?
As always, thanks a million for spending your time edumacatin’ a noob.
Scott
