Jay, thanks for the heads up. I just measured the hyperspark as compared to my current duraspark and it looks like about 1/2 inch taller. I don’t think it will be an issue for me. I will certainly find out before too long. ![]()
This post has got a lot of good information. I just posted a separate lengthy description of my experience with the Holley Sniper Stealth, MSD 6EFI ignition, and the Holley dual sync distributor with timing control on my 1970 Cougar 351C-4V.
Link: https://cccforum.discoursehosting.net/t/holley-sniper-and-msd-ignition-conversion-70-351c-4v/13887/1
70xr7tom, what link do u look under to read about it?
Should have listed that. Edited initial post to include it. Also below
Can we use the pipe plug in the block next to freeze plugs for the temp sensor? There are 2. One at front ps and one at ds rear. Just need an adapter
Aren’t those oil plugs?( I might be wrong, but that’s what I always thought they were)
Nope. Coolant! I about got drowned when i took it out and i had drained the coolant out of radiator already😀
I’ve decided to put the efi sensor on the intake and move the original sender to the ps front block plug. Easier to extend one wire vs the weatherpak connector on efi sensor
Nice! That may be my solution to the ugly brass t fitting as well. Thanks! ![]()
Let’s hope that works!. Went to ace hardware and got a 3/8Fx1/4M connector. Opened the center 5/16"hole a bit to allow the sensor to to fit down inside easier.
Another approach that assures that both temperature sensors are on the outlet coolant flow stream to the radiator is use the existing location for the EFI and install a radiator hose adapter above the thermostat in the hose to the radiator for the temperature gauge/warning light. I also shortened the vertical leg of the radiator hose. I was uncertain about the plug in the intake manifold forward of the throttle body and it was also directly under my fuel supply line. The use of the extra manifold connection is probable better if you can get the sensor tip down into the coolant flow stream but this is an option.
https://www.summitracing.com/parts/atm-2283
True. Or a much cheaper alternative is the thermostat housing that has a threaded port in it for the sender!
Just a clarification because I’m thinking about doing this on one of my Cougars, I thought with the Holley Sniper EFI unit, you didn’t need a CD box as long as you were using either the matching Holley dizzy (forget if its the hyper spark or the dual sync). I’ve always been a carb guy so figured I’m missing something obvious…? It may be as simple as I’m looking at the Super Sniper, which already has a throttle body ecu mounted. Although, I thought I thought they all did had the self tuning ecu. Edit: I’m also looking at the Holley EFI sniper fuel tank. Sounds like the pumps are internally regulated and I wouldn’t even have to run a return line? My battery is already mounted in the trunk so looks like a simple conversion.
You can use the included coil driver module, but you’ll get better quality spark with the Hyperspark CD box. The distributor you need is the HyperSpark, the Dual Sync is overkill because it also provides cam signal which the Sniper doesn’t use.
Will the Hyperspark distributor and CD module support variable ignition timing with the Sniper? Is the distributor available in a short profile like the original '70 Ford 351 distributor?
Yes you’ll have timing control through the Sniper with the HyperSpark setup. Not sure on the height of the distributors, but they have a model for 351W and 351C:
I was asking because part of the reason I used the Low Profile Holley Dual Sync Distributor (565-111) on my Cougar (https://cccforum.discoursehosting.net/t/holley-sniper-and-msd-ignition-conversion-70-351c-4v/13887/1) was to match the height of the factory distributor and retain the original air cleaner. If a low profile Hyperspark distributor was available I missed it.
https://www.holley.com/products/ignition/distributors/holley_efi_dual_sync/parts/565-111
I have the hyperspark distributor for 351W and it is about 1/2” taller than the modified duraspark it will be replacing very soon. If you need exact measurements I can get them for you.
I guess the simpler way to phrase the question is, will the original air cleaner fit with the Hyperspark distributor?
I have not installed mine yet, but: my original aircleaner sits 1 1/2” above my current Duraspark dist with plug wires installed. I have a 1/4” spacer under my Sniper EFI. That leaves an actual 1 1/4” of clearance. The Hyperspark is 1/2” taller than the Duraspark so in theory there should be 3/4” clearance from hyperspark to original aircleaner.
I can let you know for sure after I get mine installed in the next couple of weeks.
Edit: I am running an Edelbrock Rpm Airgap intake so my throttle body sits higher than a normal intake and I have not taken that into account for the possible fitment issues for you. I will have to measure from the lower flange of the installed distributor at the base of the intake to the top of the current distributor and add 1/2” to give you the exact measurement you will need in order for you to decide if the Hyperspark distributor will fit under your stock aircleaner.
