I had some time today. I thought most of the issues seemed to be centered around the ignition switch and associated wiring so that’s where I started.
My letter, color and number references are based on what is listed in the OEM wiring diagrams and shop manuals.
A-Large Black Green Wire (297) - on mine this wire is merged into a red and black wire Accessory hot when key is in ACC and Run
B-Large Yellow Wire (21) cut but connected back to the same color and size wire. Constant hot wire.
PO - Purple wire (977A) cut but connected back to the same color and size wire. Prove out. Hot when key in start position.
Next terminal not used has no reference letter or number but had a red/white stripe wire attached to the back side and it’s capped off with a red crush on wire connector
C-Red Green (16) wire has been cut and connected and merged into a black wire as well as a green wire. The black wire runs off and is connected to a white/red stripe wire that then plugs into a large pink wire that looks to go into one of the outer most terminals on a 3 prong connector. Coil power to coil in run position.
On the back side the wire is red with a white stripe. This same 3 prong has two other wires. One white with red stripe and the other red with blue or green stripe. These two wires are cut and don’t connect to anything.
The large pink wire directly connects to a red with white stripe wire that is routed to the orange twist on electrical connector that brings the red wire from the Pertronix as well as the light blue with black stripe wire that routes to the bat side of the coil.
I believe this is the 3 prong connector on the wiring diagram with wires (39) - red/white, (31)- white/red and (16) red/green or blue as all the wires appear red likely due to age.
S-Red/Blue (32) cut but connected back to the same color and size wire. Power to starter and coil in start position.
The tach connector with a large pinkish brown wire (16A) and 2 red possibly striped (16) wires is completely unused.
Original tach converted to 3 wire has a red, white and dark blue wire. The white wire is a ground that was grounded to the metal lower dash, the red wire is a power wire that was routed to the fuse box large accessory terminal and the dark blue wire went into the engine compartment and ultimately connected to the Dist side of the coil.
Dark blue signal wire from tach converted to 3 wire goes to Dist side of coil directly from tach
