I love grits and gravy. Thanks, Andy. I’m not all that smart; just lucky. If you ever find yourself on the left coast, give me a ring. We can have a few beers and talk about Cougars and physics.
The four spot welds let go on my driver side package tray strut (I don’t know that actual name). I’m going to try to take care of it this weekend.
Here’s the passenger side. It still looks good.
I’ll also order or make a metal rear seat divider to stiffen this area up. I plan on rolling some beads in it and add a couple pieces of Dynamat to keep it from vibrating too much.
Degreasing, stripping and seam/stitch welding the engine bay is going well. Here’s the back side of my passenger side shock tower. It looks like someone took a short cut when greasing the upper control arm. That shouldn’t be too hard to fix.
I’ve made some progress with my project this week.
Unfortunately, I Fastcated my $10 HF angle grinder in the process. I was wearing my welding gloves and I didn’t notice it getting hot. Oh well, I guess I know where I’m going tomorrow morning. BTW, does anyone have a tip on how to remove the transmission cooling line that connects to the rear of the transmission (return line, I think) without removing the transmission? It is kind of getting in my way.
Here’s my homemade LCA bushing press. I made it out of a 1-1/2" galvanized pipe nipple and cap and a piece of 1/2" threaded rod. It is a lot easier to use now that it all welded together.
I needed to make a little adjustment to my passenger side LCA bushing because it was just barely touching the mount.
Time to weld the bearing housings in place and box in the control arms.
Adam that patch looks great. After a coat of paint nobody would ever know that a patch was done. Thats why I like working with metal…a weld here…some grinding there…and Waa Laa, it’s as good as new!
