Yeah, I was kinda thinking that would be the way to go, but at the same time… it’s already a big enough project as is. I think I’m going to leave the drivetrain alone so that I might just be able to drive the car this summer. Then maybe next winter I can start doing mechanical stuff / engine detailing. The car runs well as-is, why hurry to make it a non-running shell? The only major problem with that method is the risk of messing up a nice new paint job by doing the dirty mechanical work AFTER the paint is done. Either way isn’t easy!
Thanks for that! It definitely helps having all the Cougar parts in the world at your disposal, and Don has been good to me with advice and some free body panels. The good news for WCCC is that we’ve sold a few roofs as a result of people seeing the video and deciding that they could tackle it. That’s pretty cool, IMO.
Anyway, some progress pics! Hood primered:
Here’s what the naked front end looks like. Note the dorky tall air cleaner. This is what happens when you want to run a K&N filter for improved performance… they apparently don’t make a shorter filter in this size. I might just go back to the stock blue air cleaner.
Numbers matching, yay!
Rust spot on the apron, boo!
Never mind, patched.
Also note the seam sealing action here:
Guy likes doing things by hand… prepping the inside of the RH fender:
Fenders got primer by the next time I went back:
There was a little aftermarket temp gauge screwed to the lower dash. Probably put there long ago by my Gramps, maybe wanting an actual degree reading instead of the vague “C - H” on the stock gauge. I debated about leaving it for sentimental value, but decided it looked kinda crappy, so the holes are now welded up.
Yesterday after work I went ahead and pulled out my heater box. Luckily it wasn’t too difficult, thanks to the car being pretty stripped out already. I probably should have documented the process, but just wanted to get it done and over with. Took this shot before removal just for reference to see where the vacuum lines and stuff go.
Speaking of the heater core job, we’ll eventually come out with a how-to video on that. We’re halfway into the process on Don’s '69, but that got sidelined. It’s not exactly the same as on a 67/68, but there are enough similarities that it should be useful for first gen owners too. Watching Don take out his '69 one helped me figure mine out, anyway.
Final shot - If cars have feelings, it’s probably horrified to be sitting where it is right now. ![]()
