I’ve searched under “wheel sticky” and can’t seem to find any threads relating to wheel fitment. I’d like to run 17" American Racing VN420 2 piece rims but have no clue what offset to run to make sure they don’t stick out. Can anyone show pics of their custom 17" rims fitting snug inside those wheelwells? Thanks!
Do a search for the Legendary wheels…WCCC has a video on these wheels as well. I believe they were spec’ed for classic Mustangs and Cougars.
I went with the 17-7 and 17-8 wheels…waiting on the 8” still.
PainterDadof2, what year is your Cougar? From my understanding, ‘69 and ‘70 can use wider wheels than ‘67 and ‘68 cars. I have 17x8” 4.5” backspacing with -1.5mm offset all around on my 1969. I can easily fit much wide rear wheels but I wanted a matching spare that could fit any spot. My big brake swap meant 14” spare wheel wouldn’t fit anywhere but the scrap yard.
I have a 68. While I like the legendary wheels and the idea of a wheel made to fit our cars, I really want the AR VN420 200s wheels. Always wanted them despite the $375/wheel tag
Off topic and embarrassing but can anyone direct me on how to post pics in these comments. Been meaning to show my new cougar here!
Give this a try
Sorry, I didn’t mean to imply you should purchase the Legendary wheels, but take a look at the offsets they come in and the various pics showing fitment. That should apply to any other manufacturer wheel in the same width/offset.
I’m running 17x7 4” backspace fronts with a 225/45 and 17x8 4.5” backspace with a 245/45 rears. Ride height has been altered in the front with a Shelby drop and 1” lower spring, rear has a 1” lowering block for an overall 2” rose height difference front to rear.
I do plan to lower the car further and run wider tires in the rear eventually.
This is close to how it sits now with the wheel and fire combo
I had those rims on my first Cougar in the 80’s. I couldn’t justify the cost this time around and ended up with Magnum 500’s instead.
I have a 69 also. Can you tell me the tire size?
I started with 245/45-17 on all four 17x8” wheels. I now have 17x9.5” rear wheels with 275/40-17 tires on the back. No clearance issues at all with these wheels.
Back spacing of 4 1/2 on the 17x8. What is the back spacing on the 9.5?
Thanks, Luke
ET 8mm
Front = 17x8” 4.5” backspacing with -1.5mm offset. What is the info on your 17 x 9.5? Not sure what ET 8mm means? Thanks.
I think I figured it out. -8 mm correct? Just to confirm does your rear tire sit below the fender lip not inside the fender? The reason I ask is my 15x8 with 4 1/2 backspace and a 245/60/15 the drivers side fender maybe only has 1" of clearance when sitting level with a 1" drop in the front.
275/40 fits fully in the wheel well. I’m certain a 295 would fit as well but the tires I use aren’t offered in that size.
Please confirm below. I only get one shot at this.
Fronts = 245/45-17 on rim size of 17x8” with a 4.5 backspace and - 1.5 mm offset
Back = 275/40-17 on rim size of 17x9.5” with a ?? backspace and - 8mm offset (ET 8mm)
Thanks, Luke
