Detailing the Engine Compartment.
Any suggestions?
The missing Smog setup i will install next weeks.
Blue is a special mixed colour taken from a low milage survivor.
It fits 99,9%
The Export brace is wrong i know but the original ones are to tiny
for these engine in my oppinion.
Looking for a correct Air Cleaner.
Plenty of vendors out there that have the correct air cleaner, blue bottom plate, shocks wrong color, master cylinder cover is not chrome, black with sliver and red decal, couldn’t tell if PS pump was correct color. Get rid of the “caution fan” decal. Autolite battery needed #27. Wrong oil cap on valve cover. Rubber smog hose a passenger valve cover should be blue, along with the fitting.
Also missing the clips for the washer fluid hose across the cowl. Black paint on inner fenders should extend past the splash shield bolt up to the pinch weld. Missing service spec decal on shock tower. Vacuum hoses for headlights don’t appear to have correct green, yellow and white stripes. Wires for pertronix should be shrink wrapped or taped to make the modification less obvious. And for good measure, I’d turn the radiator cap around.
correct air cleaner, blue bottom plate, - will check WCCC
shocks wrong color, - what color is correct?
master cylinder cover is not chrome, black with sliver and red decal, - its zinc plated ?
couldn’t tell if PS pump was correct color. - i know its wrong since its black. whats the correct paint code for the blue one?
Get rid of the “caution fan” decal. - easy fix
Autolite battery needed #27. - okay
Wrong oil cap on valve cover. - can not locate a correct one?
Rubber smog hose a passenger valve cover should be blue, along with the fitting. - easy fix
Also missing the clips for the washer fluid hose across the cowl. - easy fix
Black paint on inner fenders should extend past the splash shield bolt up to the pinch weld. - easy fix (who can provide a pict please?)
Missing service spec decal on shock tower. - easy fix
Vacuum hoses for headlights don’t appear to have correct green, yellow and white stripes. - the do have the stripes but underside of the hoses. (should i turn them?)
Wires for pertronix should be shrink wrapped or taped to make the modification less obvious. - oooops
And for good measure, I’d turn the radiator cap around. - easy fix
What is the correct Color for Ignition Coil and Bracket ?
Is the coil correct mounted? Mustard top facing back?
Who can provide a close pict of Carburator return spring and Bracket?
Shocks were semi gloss black.
Master cylinder cover was zinc plated.
PS pump was black if it is a TRW pump, metallic teal blue if a Ford pump.
Oil cap is reproduced by Scott Drake, it has a metal elbow to connect to the air cleaner base.
Windshield washer TEE fitting is incorrect too.
Coil bracket is for a 1970’s pickup truck. You need to find the right one some place.
Here’s the return spring and bracket, the carb in the picture is a C9AF-U :
Black paint on inner fenders should extend past the splash shield bolt up to the pinch weld. - easy fix (who can provide a pict please?) I think the paint is correct for 68 unless I’m thinking of a different area then pointed out. In 69 the black went up the fire wall as the vent cowl was removable and that happened mid production.
Is the coil correct mounted? Mustard top facing back? Yes, yellow facing back.
What is the correct Color for Ignition Coil and Bracket ? Phosphate for the bracket and semi-gloss black for the coil
master cylinder cover is not chrome, black with sliver and red decal, - its zinc plated ? Should be yellow zinc, but paint black is also acceptable.
I’m not referring to the cowl panel, only to the inner fender between the hood hinge and the fender flange. His black paint should extend an inch or so toward the windshield until it is basically even with the pinch weld for the cowl. Most people tend to paint the body color down to the lip like the one shown because it is a natural breaking point. I don’t have a 67-68 at the moment and can’t find a good picture.
Forgot to say the thermostat housing is wrong too. Correct thermostat housing and coil bracket in this picture. Warning - coil is an Accel oil filled unit that can take my MSD 6AL feeding it.
You are also missing the hood to cowl seal. It goes just under the windshield washer squirter brakets on the cowl. Uses little push pins and goes into the little holes on the cowl. Also, missing is the ground clip from the cowl to the hood. Mounts in the hole in the cowl on the p-side just under the hood to cowl seal. Just under and to the left of the p-side windshield washer squirter.
